Error TheEvent.cpp line 233
I have been often receiving this error message when i close LabVIEW 2009 since i installed patch 9.0f2...
Cheers!
Message 1 of 24
(7,209 Views)
I checked here [link removed; page no longer available] if it has already been reported but no.
Message 2 of 24
(7,187 Views)
Genral explanation [link removed; page no longer available]
Message 3 of 24
(7,186 Views)
Message 4 of 24
(7,184 Views)
USe this to investigate
Message 5 of 24
(7,183 Views)
Hi beetho,
This was reported to R&D (#183011) for further investigation by another customer.  Thank you for also reporting this issue.  At this time, there is not a workaround for the issue.  Please continue reporting any issues you have with NI software so that we can make our product better with your help!
Stephen Meserve
Message 6 of 24
(7,169 Views)
Has this bug been fixed or any workaround? I also received this error message quite often when launching a TestStand interface executable which is built from LabVIEW 2009
Chenny Zhenyu Wang
Certified LabVIEW Architect
Certified TestStand Architect
Message 7 of 24
(6,960 Views)
Hi chenny,
I have no information fix status or workarounds.  Please let us know if you have a reproducible instance of this error.
Stephen Meserve
Message 8 of 24
(6,926 Views)
So...three months later, any progress on this??  I'm also seeing the same thing randomly when running a LabVIEW OI executable for TestStand.  I only started seeing this after migrating existing code from older versions of LV and TestStand so I'm not sure if it's caused by the migration or just by the latest versions of the two...
Thanks!
-Carl
CLA/CTA
-Carl
CLA/CTA
Message 9 of 24
(6,776 Views)
Message Edited by Online Courses on 05-27-2010 02:30 PM
Message 10 of 24
(6,729 Views)
