automatic comparing vi and retrieve their differences
I am given a directory of VIs that I need to compare to another directory of VI and to identify what has been changed.  I am thinking to create a VI to automate the process.  I am using LabView 2009.  From the control search, I see "SCC Compare VIs.vi", but I don't see how I can get the differences information.  I want to know if there is a VI to do that?  Or if there is some method that I can get the differences automatically?
Thanks.
Peggy
(2,849 Views)
Tools >>> Compare >>> Compare VIs...
OR
Tools >>> Compare >>> Compare VI Hierachies
Will do a one to one compare and when you select as much will open the VI diagrams and put a red circle around the difference along with text describing the difference.
Do you need more than that?
Ben
(2,840 Views)
Usually you can use the steps which Ben describe above. I think there is no way to do in Labview you instead of comparing LV Blockdiagram or FP sizes in Byte. You can do it like this-> See attached screenshot. I hopt it helps.
(2,834 Views)
Because there are a lot of VIs and I was hoping that there could be some automatic way to capture the data.
Thanks for all the input!
Peggy
(2,823 Views)
