array of references
Hi
I have several commands that I want to control through references... I can create an array of references and this seems working. However if I make a cluster of an array of references and another reference to another object, the array is not appearing in the cluster ...
Something like this
(2,259 Views)
Accepted by nitad54448
Unbundle by Name only shows elements that have labels.  The data coming out of Build Array has no label, so that element in the cluster has no label. To see all the elements use the plain "Unbundle" function.  (If you like, I can give you an XNode that adds a label to data in a wire.).
(2,251 Views)
Great, thanks for help.
I suspect I need to add a Label to the array, since adding to an element does not change anything.
How to do that ?
(2,236 Views)
That's because your array does not have a name.  Create a constant for your cluster and wire that up to the Bundle.  Be sure to name the array.
(2,235 Views)
Alternatively you can attach a label by type casting to a labelled constant (which i've used a couple of times), but in general i'd suggest Crossrulz suggestion. 🙂
Qestit Systems
Certified-LabVIEW-Developer
(2,109 Views)
