array multiplier to get specific size
Accepted by mangood
Hi mangood,
What error codes are you seeing when you attempt to run that code? It works on my computer with simulated I/O.
Also, since they are both 1D arrays, why don't you have the two memory items in the same loop and multiply inside of each for loop instead of implicitly forcing it to create arrays and then multiplying them?
Please attach code too.
Best,
Joey S.
Senior Product Manager, Software
Message 11 of 12
(502 Views)
@j_spin wrote:
Hi mangood,
Best,
thank you the problem was solved
hi ?Q>
Message 12 of 12
(484 Views)
