array multiplier to get specific size
hi
i have two array the first on is 4*2 and second one 2*1
i need to mulipliing  them  to get 4*1
this is my vi
can any  simple modification to this vi to get the result ???
best regards
m.s
hi ?Q>
Message 1 of 12
(5,650 Views)
Please tell us exactly how the output should look.  I modified your VI to have two 2D array controls which could be your inputs. I set default values which will likely create a clealry identifiable pattern in the output array.  Set the values in Out 4x2 the way you want the program to calculate for the specified inputs.  Make that value Default. Save. Post modified VI.
Lynn
Message 2 of 12
(5,645 Views)
  1. Convert your Arrays into Matrices (use the Array-To-Matrix VI)
  2. Do matrix multiplication
  3. Convert the resulting Matrix back into an Array (use the Matrix-To-Array VI)
Certified LabVIEW Developer
Message 3 of 12
(5,642 Views)
thank but thier is no array to matrics and matrics operation in  my labview fpga
is thier another method????
regards
hi ?Q>
Message 4 of 12
(5,628 Views)
Lynn
this is vi with simple vlaue
as you request
thank in advance
hi ?Q>
Message 5 of 12
(5,626 Views)
Lynn
also i note if i use this method in labview fpga this error appear
hi ?Q>
Message 6 of 12
(5,619 Views)
It is important to explain that you're using FPGA in your first post. You'll need to find an alternate way to do what you want, because "The FPGA Module supports only one-dimensional, fixed-size arrays." If you can explain what your inputs and outputs are without using a multi-dimensional array, perhaps we can help find a way to compute your desired result.
Message 7 of 12
(5,608 Views)
thank you for this information
i have simplfy my circuit to be this
and this my implemention
but also error appear
can some help??
hi ?Q>
Message 8 of 12
(5,590 Views)
Please, try to provide lots of detailed information. What error occurs? Why are you using two separate For loops? Why not put both memory reads in the same loop along with the multiply, so that you are multiplying scalars instead of arrays?
Message 9 of 12
(5,558 Views)
now i know what is the problem...
the problem in labview fpga is that you can not pass array between two loop that work in parralel???
hi ?Q>
Message 10 of 12
(5,550 Views)
