array manipulation and arithmetic
I currently have a VI that reads and stores values from a 1D array to a 2D array.  I'm stuck trying to save the intial values from the
1D array to perform arithmetic functions.
I have uploaded the VI and added some notes in it to provide some clarity on what I currently have and what I'm trying to accomplish.
Any help would be appreciated.
Thanks!
(4,080 Views)
The trick is to create another shift register to hold the very first values of the Current Data.  Then you have a value to divide by for subsequent data entries.  See attached VI (LV2009).
- tbob
Inventor of the WORM Global
(4,066 Views)
Thanks tbob for all your help with my questions.  Unfortunately i have LabVIEW 8.0 and I can't open the
VI that you posted using LabVIEW 2009.  You think it's possible that you upload an image of the block
diagram so i have a better idea about the recommendation you mentioned?
thanks!
(4,055 Views)
Accepted by vjm-ndt
- tbob
(4,046 Views)
this is definitely the solution!  Kudos!!
(4,029 Views)
Don't forget to initialize the second shift register when using the Clear command.  This gets the placeholder for the next Add Data command.
- tbob
(4,018 Views)
