application builder
Hi, im wanting to build an application out of my .llb. But have not done since 2004. Currently im using labview 8.6, are there any guides that can help me??
Thanks Stuart
(3,360 Views)
Not meaning to be blunt, but there is the LabVIEW Help. Have you checked that? Presumably you have the Professional version of LabVIEW or you have the Application Builder as a separate add-on.
You should only be using LLBs for distribution. You should be converting your LLBs to lvlib. lvlibs are far superior to LLBs, which were (and still are) problematic.
Message Edited by smercurio_fc on 04-06-2010 08:54 AM
(3,356 Views)
Accepted by stu22
If you are trying to build applications, please have a look at the attached link which details this process
As Smercurio_fc correctly points out, I would recommend including all of your LLBs to lvlib files as you will find distribution much easier.
Many thanks,
Andrew McLennan
Applications Engineer
(3,325 Views)
oops missed the lv off my llb's.Smiley Very Happy Thanks Andrew that link solves my problem.
(3,319 Views)
