Could you please post your LabVIEW code showing us what you are doing now?
I am allowed to answer questions. Writing code requires a purchase order be in place first ![]()
I will watch for you to post your example.
Ben
Message Edited by jiankang on 02-27-2006 11:10 AM
HI Jiankang,
There are still lmits to what computers can do. I hope your real life application does not go so hard on the CPU ![]()
10,000 data points just can not be represented by the number of pixel you have to work with. For pseudo-real-time updates keep the sample count down.
I did a quick experiment and it looks like I can do 50 plots with 100 points each and recycle them pretty quick.
Your sub-VI now looks like this
And your toplevel looks like this.
The revised example is attached.
Using this method I could keep a steady stream of updates going and still had time left to let be play with changing the view. I do not not know if this helps.
Ben
Message Edited by Ben on 02-27-2006 07:38 PM
Message Edited by Ben on 02-27-2006 07:39 PM
Thanks so much, Ben.
Your code doesn't require update the 2D arrays all the time and runs much better than mine.
Is the size of 3d graph only limited by the computer?
I am modify my code according to your example. My task is to read the data from frontend, process it and display the waterfall.
I am changing a little to make the waterfall to move forward instead of "sweep". After the maxima number of spectrum is reached, the earliest spectrum will be removed and the new spectrum will be the last plot. I have almost done and will post it later.
Thank you in advance Jiankang!
The best answers to questions are those that are posted by the original poster. The rest are just guesses.
Ben
