01-04-2010 01:33 PM
01-04-2010 01:52 PM
From the Analytic Geometry sections of some math handbooks:
The equation of a line passing through two points is: (y-y1)/(x-x1) = (y2-y1)/(x2-x1)
The general form of the equation for a straight line is: A*x + B*y + C = 0
The angle omega between two lines A1*x + B1*y +C1 = 0 and A2*x + B2*y + C2 = 0 is tan omega = (A1*B2 - B1*A2)/(A1*A2 + B1*B2)
You can do the math to convert the equation in two-points form to the general form to get the angle.
Lynn
01-04-2010 01:52 PM
01-04-2010 02:48 PM
01-04-2010 02:57 PM
01-04-2010 03:14 PM
01-04-2010 03:21 PM
01-04-2010 03:28 PM
12-15-2019 12:15 PM - edited 12-15-2019 12:34 PM
I am aware that this thread is very old, but things gets much simpler if we use complex math. Try it!
(see also)
12-16-2019 11:26 AM
So are you saying that the real solution is to use imaginary numbers?
