android shared variable
if you have dhcp enabled, the router assigns ip address to all device connected.
Check all ip address and look in "Distributed system manager" the value and address of shared variables.
Message 11 of 19
(3,279 Views)
yes the router use dhcp.
this is the screenshot
How i see in 192.168.0.5 not include shared variable.
in 10.211.55.6 there is shared variable but i can't change address.How i do that?
Message 12 of 19
(3,275 Views)
i'm tring to use "web publishing tool" to use browser to see front panel, but i have ALWAYS the address 10.211.55.6!!! how can i change it to 192.168.0.5?? thanks 🙂
Message 13 of 19
(3,258 Views)
If you right-click on My Computer in the project Explore and select the Properties.
What are the value of the Address under the General Category?
Also Under Tools-> Option->Web Server there are configuration of your NI Web Server.
How are the Web Server configurated?
Message 14 of 19
(3,243 Views)
thanks. I set now on My Computer the address 192.168.0.5, but the address 10.211.55.6 is always used.
In web server i don't change anything, i have this screen:
Message 15 of 19
(3,237 Views)
Accepted by TommyR222
Are you really sure that your PC has that IP address 192.168.0.5 ?
Are you runing Windows as primary OS?
Message 16 of 19
(3,230 Views)
AHH this is the problem!
i run windows on VM and the address was different!
now works! 🙂
thanks
Message 17 of 19
(3,215 Views)
Hi Vondes,
You've posted on an old post that already is marked as having a solution. It is better to start a new post, so that people know it is not related to the original query and has not been answered yet.
Message 18 of 19
(3,113 Views)
@Gregory wrote:
Hi Vondes,
Not only that, it looks simply like spam!
Rolf Kalbermatter  My Blog
Message 19 of 19
(3,106 Views)
