04-09-2020 03:16 AM
I am trying to follow the instructions in the attached file. but I get an error "an error occurred trying to load the assembly", in the step on page 7.
Can you help with these?
04-09-2020 04:23 AM
04-09-2020 04:29 AM
I am using NI LabVIEW 2018 SP1(64-bit)
04-09-2020 04:40 AM
Hi BaJa,
So there are two problems with your LabVIEW version:
While the first item can be tolerated, the second item is (most probably) the source of your problems!
Switch to the 32bit version of LabVIEW - or ask ThorLabs for a new version of their hardware driver with support for 64bit LabVIEW…
04-09-2020 05:21 AM
I have sent this inquiry to Thorlabs, but how can I Switch to the 32bit version of LabVIEW!
04-09-2020 06:23 AM
