10-23-2008 06:47 PM
10-23-2008 07:54 PM
Just in case the link doesn't brings you there...
Here's the URL http://www.ni.com/devzone/idnet/
10-24-2008 10:21 AM
10-24-2008 10:47 AM
The term plug and play is a bit generic, imho, since you can have LabVIEW or CVI plug and play. Just to be clear, what you are looking for is a native LabVIEW driver?
10-24-2008 10:52 AM
legacy12,
I realize that you likely have already seen the drivers that are available at NI.com, but I would like to make a reference for others looking for drivers for those instruments.
I also want to concur with the other AE's that PnP drivers for these instruments are not available from National Instruments or Agilent.
10-24-2008 05:40 PM
12-21-2010 02:55 PM - edited 12-21-2010 02:56 PM
Hi
I am currently searching for the same thing. Any luck of getting Plug and Play drivers for the Agilent N9010A?
12-21-2010 03:04 PM
Is the rest of your project done in the "Plug N Pray" mode (IVI)?. There are LabVIEW drivers for the instrument you are asking about, just not the IVI type.
12-21-2010 03:11 PM
I just got this instrument and have downloaded the Labview IVI drivers but there are is a lot thats left out which i believe would be on plug and play drivers. Example....i cant get a VI to choose the Mode of the instrument (EVDO or CDMA2k). Am i looking for the wrong thing here? I believe Legacy12 had similar issues and the NI Engineer mentioned that plug and play drivers werent available.
12-21-2010 09:45 PM
There are 3 instruments discussed in this thread. Which one are you asking about? I know for a fact that there are LabVIEW drivers for the 9010 and the 34980. Did you do a search?
Even the LabVIEW drivers may not implement each and every function.It's a simple task to edit and modify if necessary.
