add to an already existing wav file
Hi
I am working on processing of audio files.
Suppose I have multiple .wav files. Is there any wav to append all the wav files to some other file?
(3,059 Views)
There's lots of programs available to merge audio files out there. Google for them. Some will have a command-line interface that you can call via System Exec.
(3,050 Views)
smercurio_fc
I did search , however all the examples are of merging not appending. I mean if I have 2 files of 40s and 20s then the resultant file should be of 60s
(3,037 Views)
I cannot find any suh examples. Can anyone help ?
(3,026 Views)
I did a search for append 2 wav files and a number of tools came up. You will have to try them to see if they are suitable. to get you started theres sox (command line tool that does a cross fade tape splice) and wavjoiner (not sure if it has command line interface).
Hope it helps
TD
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(3,020 Views)
@su_a wrote:
smercurio_fc
Merging and appending are the same thing.
(3,015 Views)
