02-13-2012 08:53 AM
I have a question regarding the C-Series Module NI 9871, 4-Port, RS485/422 Serial Interface.
I need to find out how it recovers the data from the link. I need to compare it with 8b/10b encoding.
Does anyone know what UARTs are used or how the data is recovered.
John Lee
02-17-2012 04:00 AM
Hi John,
Thanks for your post. I am not 100% sure what you are trying to ask . Would you like to know the differences in speed/data rate between this module and 8b/10b? Or more specific internal information about the RS-485/RS422 Transceiver? If you could give me more information I will try to help you as best I can.
Best Regards,
02-21-2012 11:00 AM
Hi Benjamine
Thanks for getting back to me.
I wanted to know how the NI 9871 recieved the data on the RS485 link.
I believe it has a RS-485/RS422 Transceiver followed by a UART.
The UART will recover the data as per normal comms.
I need to recover data from a link which has 8b/10b encoding.
I think my answer is to use RS485 Transceivers and then push the serial data into an FPGA for data recovery and 8b/10b decoding.
Regards
John Lee
02-23-2012 07:34 AM
Hi John,
I have had a look into this and I cannot find any specific information on the Transciever or UART. However I have come across an example using the 9871 with processing on a cRIO FPGA.
To find this example open up Labview » go to Help » Find Examples » Search for 9871 and open up NI-987x Serial Loopback.lvproj.
Hopefully this should give you a good start. Once your serial data is passed onto the FPGA you can then decode the 8b/10b within the FPGA code.
Best Regards,
