add a scipt node
Hi all,
I am new to Labview and I want to ask how to add a script node (Matlab script) to a VI, since I can not find it in the function palette. Is that because it is not in base package? Do I need to install other packages?
Thank you,
Hannah
(3,409 Views)
Matlab scripts are not incuded in the base version of LabVIEW.
(3,408 Views)
Thank you for your help,
However I use a professional version of Labview. Do you know where the script node is in the function palette?
(3,404 Views)
On your function palette, there is a search button. You can use this to find the matlab script node.
p.s. It's on the Mathematics>Scripts and Formulas>Script Nodes.
Message Edited by Dennis Knutson on 08-09-2007 07:53 AM
(3,386 Views)
I got it. Thank you very much. I find out that the problem came from my Matlab version, I reinstalled it then the program ran well with Matlab script.
(3,374 Views)
