acquiring a webcam image without vision toolbox
I am trying to capture an image from a webcam (or even a cheap digital camera) as part of a project I am doing. I simply want labview to take a picture and save it on command. However, everything i have searched requires the vision toolbox (a $4K+ addition) which is simply out of my range as a student. Does anyone one know a simple way to capture and save an image?
Thanks!
Message 1 of 14
(38,843 Views)
Hi CanadianK...,
see this link please. You can change the example to only on WebCam.
Hope it helps.
Mike
Message 2 of 14
(38,825 Views)
Do you know if you can record this though? or take a snapshot? I need to set it up so that I can  rotate an object and take snap shots every few degrees of rotation.
I can get the webcam to view in, however I cannot find a way to take the image such that it can be stored.
Thanks!
Message 3 of 14
(38,813 Views)
Hi CanadianKyle,
there is also a command to send the image to the clipboard. You can then read it from the clipboard to store it to a file.
If you don't find it, then i can send you an example in the evening.
Mike
Message 4 of 14
(38,795 Views)
Hi CanadianKyle,
attached you will find an example which shows how to take a snapshot from your webcam.
Hope it helps.
Mike
Message 5 of 14
(38,779 Views)
No it is not working. how i can take snap from laptop camera to labview front panel.
Message 6 of 14
(36,357 Views)
Hi CanadianKyle,
Examples, tutorials and articles on interfacing a webcam with LabVIEW without NI-IMAQ or some type of NI Vision Acquisition Softare are scarce. Depending on the lifetime of the project you are working on I would recommend downloading an evaluation copy (free for 30 days) of NI-IMAQ from ni.com. You can then make use of a number of examples to accomplish your goal including the one in the URL below:
https://decibel.ni.com/content/docs/DOC-3479
Otherwise, I can refer you to these forum posts that could possibly be of some hepl to you:
http://forums.ni.com/t5/LabVIEW/2-hours-finished-the-webcam-program/m-p/782481?requireLogin=False
http://forums.ni.com/t5/LabVIEW/Grab-images-from-USB-Webcam-Peter-Paret-s-driver-too-slow/m-p/736552...
http://forums.ni.com/t5/forums/searchpage/tab/message?submitted=true&q=avicap32.dll
The evaluation copy of some NI Vision softare is probably you're best bet. Without it, my research doesn't seem to show any standard or straight-forward way to interface a laptop webcam with LabVIEW.
I hope this information helps!
James D.
Message 7 of 14
(36,325 Views)
You could use ADVision Toolkit, http://vi-lib.com/ - it's an OpenCV wrapper. It does have all the limitations of OpenCV, but for simple webcam capture, it should work OK.
Message 8 of 14
(35,862 Views)
This lib work in LV 2012 ?. thank in advance.
Message 9 of 14
(34,164 Views)
hi NICOLAS2013par,
I haven't tested it in detail, but I was able to install ADV-1_2_6+ (I use plain LabView, no Vision Toolkit) and run those vis I needed - I used LabView 2013 SP1 32bit  on  windows 8.1 64bit
Alex
Message 10 of 14
(32,846 Views)
