access class from seperate loop
Here's where I'm at. I need at access the data members of the positioner class from the second loop. I cant seem to figure it out.
As you can see... I'm new at LVOOP.
(3,091 Views)
Accepted by WayneS1324
Search for the design pattern called "Sinlgeton".
A non-LVOOP version would be called an Action Engine.
Ben
(3,089 Views)
I will do that Ben... thanks.
One quick question though. Is there any reason I shouldnt create an indicator at the right shift register in the top loop, and then use
a property node (value) in the bottom loop?
EDIT: The purpose is to use OOP though. Unless I dont understand correctly.
(3,083 Views)
First quick answer is "the indicator on the outside of the loop will not update until the loop is done.
If inside just prior to SR, sure you can get away with it but you are opening up a situation ripe for a race conditions.
Singlton is the LVOOP answer.
Ben
(3,073 Views)
Thanks Ben.
(3,065 Views)
