about flat sequence and time elapse
My purpose is to make the second frame working after 1 second. I used two different method in the first and second attachment. The first was run well while the second one fails. I can't see why the difference exist. All I did is to justify whether the time elapse is greater than 1.
(3,096 Views)
What do you mean "the second one fails". It correctly indicates that 1 second has elapsed.
Using a flat sequence structure here is just silly. It does absolutely nothing that the wire between the first and second loop already does. Also, very bad idea to write code where you have to click on the Abort button in order to stop.
(3,089 Views)
The numerical indicator should turn from 0 to 1, but when I simulate that the numerical indicator does not change
(3,083 Views)
Accepted by shuishen1983
It does turn to 1. On the other hand, I would strongly recomend that you stay away from dyanamic data. As you can see, it's coerced to both a numeric and Boolean. The result of a Greater function should be a Boolean and that would be something you could not wire directly to a numeric. You can connect dynamic data to anything and result of that, I believe, can be somewhat unpredictable.
(3,076 Views)
An Express VI for a greater than operation???  Come on NI. Smiley Mad  What the hell are you thinking?  The only Express VI worth keeping is the Elapsed TIme function.
Which would you rather use:
- tbob
Inventor of the WORM Global
(3,053 Views)
