ZES LMG 500 for harmonics
All,
I have a LMG 500 with harmonic. Does anyone know how to measure the harmonics using LabVIEW?
thanks, erez
Message 1 of 13
(4,203 Views)
Hi erezg
Check this and let me know if it helps
Astromaut
Message 2 of 13
(4,144 Views)
Dear Astromaut,
thanks for the fast reply. The link you sent is about analyzing signal, I'm looking for a vi that will download the harmonics from a power analyser (the LMG 500).
thanks, Erez
Message 3 of 13
(4,140 Views)
Hi erezg
I found another forum that might be useful. They referenced this help document.
I will continue searching to see if I find something else.
Astromaut
Message 4 of 13
(4,109 Views)
Hi Astromaut
still not what I need 😞
I want to use the Zes lmg 500 to download the hermonics - I can continue from there.
Thanks again, Erez
Message 5 of 13
(4,073 Views)
What options (connections) for data transfer do you have?
Have you tried the LabVIEW driver ?
Greetings from Germany
Henrik
LV since v3.1
Message 6 of 13
(4,071 Views)
Hi erezg,
I guess you already know this.
What else do you need? (If there is a device command not implement in the driver you will find all the relevent information in your device manual!)
Message 7 of 13
(4,069 Views)
Hi
I need the commands sequence to measure the harmonics. Tried the manual, but no luck. I was hoping someone already wrote it.
Thanks, erez
Message 8 of 13
(4,062 Views)
In LMG500 user manual refer page number 135- that is interfaces, where you will get command set.
Expand.Evolve.Influence
Message 9 of 13
(4,055 Views)
tried, with no luck...
Message 10 of 13
(4,003 Views)
