03-27-2018 05:54 AM - edited 03-27-2018 06:04 AM
below are the command list for harmonics.
2.2.8.2 <list>
With the <list> parameter you can get several values with one command from a list or array.
<list> is a short form for <(<NRf>:<NRf>)>. The results are separated by comma, see
following example:
Output of AC voltage and the harmonics of order 1 to 3
You have to send (here as SHORT command):
UAC?;HUAM (1:3)?
The instrument response will be
223.45;221.75,0.3456,5.6789
The first part of the answer is the AC value of the voltage. The following semicolon
separates this answer from the second part of the request (the requests were also separated
by semicolons!). In the second part of the answer the three values are separated by comma.
03-28-2018 01:20 AM
The LMG has 2 modes: harmonics and regular. To measure the harmonics I need to switch mode. Could not find the correct wat to do that
03-28-2018 03:19 AM
In below link Go to -->Application note-->#108Programmers guide and example
https://www.zes.com/en/Products/Discontinued-Products/Energy-and-Power-Meters/LMG500
you will get details
