Yscale format in intensity graph
I want to be able to edit the y scale for the intensity graph as in the photo.
Ex: [1/2],[1/3].....[38/1] etc. Format value edit feature nodes on y scale [%d/%d].
However I don't know how to pass this graph as 1D two arrays respectively [1/2] for y value
I added the numbers I used in the array to the txt file.
thank you for your help
(934 Views)
Hi idil,
An Y scale can only represent one number per tick, so y format string of "%d/%d" doesn't make any sense!
The data in your text file also doesn't make a lot of sense as there are just two rows with lots of numbers (or two very large integer numbers)…
Do you want to show two Y scales for your intensity graph?
(916 Views)
Your file shows two long string of decimals (no delimiters), one for Y1 and one for Y2. What do these digits represents? How do we read those into a numeric datatype? (single? Pairwise?)
Where exactly is X? Where is Z?
I agree that your question and pictures make very little sense. Can you attach your Vi instead. Explain in detail how you want the result to look like.
(898 Views)
