YAML to JSON converter
Just in case someone finds this useful.
Here is a simple YAML to JSON converter.
It uses yaml-cpp (https://github.com/jbeder/yaml-cpp) and tojson (https://github.com/mircodezorzi/tojson) to do the job.
The wrapper is written in LabView 2020.
It is fast and light-weight.
Feel free to use it in your projects.
In case you like it give me a Kudo.
Greetings, Manfred
(2,521 Views)
This is Windows 64bit only
There is a project here : https://gie.gcentral.org/team/YAML-JSON-YAML
It doesn't mention is it's going to be available on all plateforms (Linux, RT, etc..)
Epictetus
Antoine Chalons
(2,452 Views)
Thank you for providing this. I am loathe to use this tool, as it does implicit type conversion, such as turning "NO" into "false" (the "Norway Problem"). I am working on a LabVIEW-native implementation that follows the ethos of StrictYAML, which should interpret all yaml scalers as strings. But, with caveats, the above tool is a good starting point!
From this point, you can use the LabVIEW JSON tools to extract required data from YAML!
_____________
Creator of the BundleMagic plugin for LabVIEW!
(1,226 Views)
