Programmatically set class wire designs?
Is it possible to programmatically set the wire pattern and colors for classes?
I'm using the VIs that LabVIEW provides to set VI, class and library icons, and that works great, but I don't see any way to programmatically set the wire designs or colors for classes.  Since the tools to access the icons is so complete, allowing control of individual layers for example, it seems like they would have added the ability to configure the wires as well, but I can't find it anywhere.
Is there maybe some undocumented feature somewhere that would allow this?
Note: I'm using LabVIEW 2024 Q1 (64 bit).
(1,479 Views)
I think you might benefit from looking at this earlier thread asking similar questions that got some promising results:
https://forums.ni.com/t5/LabVIEW/Class-Properties-Dialog-Box-Wire-Pict-Ring-Location/td-p/4029122
(1,455 Views)
(1,440 Views)
