Y Controls
Here is the issue I'm currently working on:
Message 21 of 46
(2,573 Views)
Ok; I fixed that. But I'll hold off throwing out another version until I get more feedback.
Message 22 of 46
(2,556 Views)
Seems like VIPM isn't going to work for me.  Now I have to invent my own packager.  Shouldn't be too hard.
Message 23 of 46
(2,523 Views)
Based on the lack of feedback, I infer that there's little or no interest.  But I've been using Y Controls, finding issues, and fixing them.  Since no one else appears to have been participating, I haven't concerned myself with backward compatibility,  I'm getting close to sharing a new version.  Anything made with the old version will be broken.
Message 24 of 46
(2,425 Views)
I'm still interested but lack of time to really test.
greetings from the Netherlands
Message 25 of 46
(2,419 Views)
Y Controls cannot be made to work reliably with LabVIEW 2018 or earlier (due to a bug in those earlier versions).
Here is a version that works with LabVIEW 2019 +.
I am not aware of any bugs in this version.
Message 26 of 46
(2,412 Views)
To test my first Y Control, I put it on the front panel of a "Dialog Using Events" instance and saved it as "test.vi". The Y Control operates as expected when running the test.vi.
Then I made a Build Specification that produces an application of the test.vi. The application builder builds the *.exe without complains. (In LabVIEW 2019 SP1, the Build Specification just contains the test.vi as the Startup VI.)
When running the application I get three error messages in the following order.
Error 7 occurred at Open VI Reference in Y Control Ability Manager.XCTL:Init.vi->Y Control Ability Manager.XCTL:Init.vi.ProxyCaller
Error 7 occurred at Open VI Reference in Y Control Ability Manager.XCTL:Facade.vi:2840002->Y Control Ability Manager.XCTL:Facade.vi.ProxyCaller
Error 7 occurred at Open VI Reference in Y Control Ability Manager.XCTL:Start Y Control Event Handler.vi:5270003->Y Control Ability Manager.XCTL:Facade.vi:2840002->Y Control Ability Manager.XCTL:Facade.vi.ProxyCaller
After confirming each of the errors the application executes and I can operate on the numeric controls - but it seems that the Event Handler of the Y Control is not operating/executing: I can operate on the front panel, but the Y Control logic is lost.
Is there anything that I have missed in the Build Specification?
Message 27 of 46
(2,366 Views)
The bug happening when my Y Control system is trying to access info about your Y Control's .lvclass while the class is inside the .exe.  It will take a while for me to resolve this.
Message 28 of 46
(2,322 Views)
Thanks for your prompt response, Paul.   I did not dive into the details of the Y control implementation when I got these errors.  As I take from your answer, you have identified the root cause.  These are good news.  Happy coding, Paul
Message 29 of 46
(2,314 Views)
Try this.  It's backward compatible with version 2.0.0.0, so no need to remake your Y Control.  Just install this over ver. 2.0.0.0; and no need to restart LV for this change.
Message 30 of 46
(2,304 Views)
