XY graph using formula node
In a formula node there is one input(x) and two outputs(y1,y2).
Plot y1,y2 on a single XY graph for different x1 values(from 100-200). please reply...
regards,
jathin
Message 1 of 14
(7,732 Views)
Accepted by Jathin
Please post your code, regardless of its state.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 14
(7,728 Views)
inputs: X
outputs:Y1 and Y2
with different values of X plot Y1 and Y2 using Formula node
note: X values are from 100 to 200.
for any code..please do it and attach
please reply
Message 3 of 14
(7,720 Views)
Hi Jathin,
this sounds like a school assignment. This forum isn't intended to do other peoples homework.
This assignment also is very basic stuff, which should be easily to solve after going through basics course offered by NI...
And, as said before, we will help to develop code as soon as you attach your work here. We will not write stuff from scratch...
Message 4 of 14
(7,704 Views)
I attached the file I did is this the way the problem can be solved or sugges any steps...Please reply...
Message 5 of 14
(7,684 Views)
Look at the XY graph Example VI in the Example Finder.
You want to use one of the Multiplot data structures.
Message 6 of 14
(7,679 Views)
But its not coming when i tried to do like that it is showing error when i attach a wire from the bundle to the multiplot graph ...please help...
Message 7 of 14
(7,676 Views)
What you posted seems to meet your requirements. (Correction: I see that you are to have two plots. Follow Ravens Fan's advice)  I like to keep the wires straighter and the block diagram more compact but those have no effect on performance. Avoiding coercion dots is probably a good practice to adopt. In this case not problems will occur but it is better to know how things are being converted rather than relying on the default conversion.  It is good practice to document both the block diagram and the VI itself (VI Properties >> Documentation).
The formulas you chose are not the easiest to visualize as far as verifying the correct performance. If you connect to i (rather than the random numbers) and arrange the arithmetic functions to make x increase monotonically from 100 to 200 you will see the sine waves.
Lynn
Message 8 of 14
(7,670 Views)
What does the error say?  Post your VI again.
Here is what I have.
Message 9 of 14
(7,669 Views)
But i have to plot from 100-200 know...the x values should be from 100-200
Message 10 of 14
(7,662 Views)
