How to insert several 1d arrays into a 2d arrays?
I've posted something similar to this, and I thought my problem was solved, but, I'm again in trouble.
my problem is this one at the video.
http://www.youtube.com/watch?v=wSAw9m-z6dM&context=C30f82aeADOEgsToPDskL8SKJlGaKcY0TQ1Z3KJuUL
thank you all in advance.
(2,820 Views)
Accepted by topic author ManuSpadim
I could not look at the video..
DO you mean insert 1D arrays into an existing 2D array?
Are the 1D arrays of the same type?
The easiest method would be to use the build array and right click and select concatenate inputs.
It will put the new 1D arrays at the bottom of the existing array.
If you are building a new 2D array, same as above, but do not concatenate inputs.
(2,809 Views)
thank you very very much!
worked perfectly!
(2,796 Views)
