XNET buffer problem
Accepted by mexaviesta
The 30bit is NOT your device sending that. No CAN tool supports more than 29bit for a message ID.
The only reason you got a 30bit ID from the NI-CAN driver, is that the driver adds the 30th bit to the message ID.
This has been NI's implementation to let you as a programmer know that is an extended message ID (29bit) and not a normal ID (11bit). This is also used in the driver when you want to send a message with a extended message ID.
The 30th bit is not transmitted on the bus.
But again, this is only valid for NI-CAN and its driver, not a standard CAN.
The XNET driver works in the correct way, giving you a flag (boolean) that tells you if the message ID is normal or extended.
Message 11 of 13
(1,871 Views)
thank u very much, i got it!
Message 12 of 13
(1,864 Views)
Remember to mark a solution, if you problem has been fixed.
This way peolpe can see that your problem has been resolved, and what answer did help you solve the problem.
Message 13 of 13
(1,847 Views)
