XML Parser Memory leak
HI,
I'm using the native XML parser palette to edit SVGs (color, width, height) to show icons in my application (using G-Image from VIPM to rasterize them). By using the Desktop Execution Trace Toolkit (DETT) after having a big memory leak in my application (it used all my computer available memory during the night), I found memory leaks in my XML edit VIs. It makes sense because these VIs were called every seconds, generating 3 memory leaks each time. And after fixing the issue, I've been able to run the application all night long without memory growth.
Here's the issue / fix: (LabVIEW 2024 Q3 64 Bit)
When calling Get Named Item method on a Node Attributes, if the given attribute Name is found, the returned Node reference is seen as valid by Not a Number / Path / Refnum? and if the attribute name is not found, it is seen as invalid.
Usually in LabVIEW, refnums seen as invalid by Not a Number / Path / Refnum? do not need to be closed and will generate an error if closed (queues, DVRs, VI references, ...). So I thought I didn't need to do it on the XML Node.
Big mistake!!!
Here is a small example (see attached zip, code saved for LV 2020):
thomasallibe_3-1786612441497.pngthomasallibe_3-1786612441497.png  thomasallibe_5-1786612625699.pngthomasallibe_5-1786612625699.png
We can see DETT detecting memory leaks when the Invalid Nodes (Not a refnum) are not closed.
So,
- Is it expected to close all XML parser refnum, even invalid ones?
- Is it a bug that Not a Number / Path / Refnum? sees them as invalid even though they lead to allocated stuff?
- I've tested only this Get Named Item method, but it may not be the only one with the same behavior.
Message 1 of 13
(660 Views)
That clearly seems like a bug.
Maybe that's related, but you can also see that the flattened "Ref" from the invalid refnums has a non-zero value, while it should definitely be zero.
From experience, I have learned to always close an XML Parser refnum. Whatever its validity, it will be always safe to close it.
Raphaël.
Message 2 of 13
(616 Views)
Good find! I assume it creates the reference regardless, but it points to Null if not found, that's why you need to close/free it.
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 13
(607 Views)
I've reported it as a bug to NI
Message 4 of 13
(587 Views)
I think there is an EasyXML LabVIEW library out there that is literally hundreds of times faster than the native VIs. It's a little less user friendly, but much more capable.
Bill
CLD
(Mid-Level minion.)
Message 5 of 13
(528 Views)
I agree on this:
However on this it's the other way around!
EasyXML (which you can get from VIPM) allows to easily and efficiently read/write most LabVIEW data types from/to XML, but that's it.
If you need to perform more complex XML tasks (search/edit/add/remove nodes, get/set attributes, process namespaces, validate against a schema...), to my knowledge the native XML Parser palette is the most reasonable tool. It may not be suited for giant XML files though.
Raphaël.
Message 6 of 13
(512 Views)
@raphschru wrote:
I agree on this:
Raphaël.
Yes, the best tool for the occasion. I'll use the native XML VIs for simple tasks, but in one of the related topics (can't recall it ATM) it from like five minutes to less than a second.
Bill
CLD
(Mid-Level minion.)
Message 7 of 13
(496 Views)
You're not the first person to note a memory leak.  While this doesn't go into as much detail, you can see here:
https://forums.ni.com/t5/LabVIEW/Is-this-memory-leak-in-XML/m-p/4236140
Also, I have posted about it before, but the built-in LabVIEW XML parsing is quite slow.  See here, though the article is from 2013 I tried a while back and I still had a lot of slowdown when I tried using the built-in parser as well.
There's another post here that does speed trials on XML reading, showing that LabVIEW's XML reader slows down exponentially with the size of the file.  If you increase the number of elements in XML from 20 to 210, you'd expect the execution time to go up by a factor of 10 to 11, but in the experiment it goes up by a factor of 76.
Solution is unfortunately to rewrite all your code using a different XML library.  Despite it coming out in 2005, LabXML still works pretty good and is much faster, though it does only work on 32-bit.  There are probably other options as well, I haven't looked much.
Message 8 of 13
(435 Views)
For my use case the built in parser is enough, for now. It's slow for a XML parser, but I only load 1 or 2 simple SVGs on a panel. I don't even bother caching the icon, which would be a good improvement. I went for the easiest implementation.
As an alternative to parsing XML entirely, I think I could just perform string manipulation.
I only do 2 simple things on my SVGs:
- set "width" and "height" attributes on the "svg" tag.
- set "fill" and "fill-opacity" to the "style" attribute of all the "path" tags.
Message 9 of 13
(393 Views)
I'm no expert here but I'd be careful. You couldn't just search for the words, as you'd need to ensure that "fill" is within a "path" tag... which sounds like XML parsing to me 🙂
And don't forget, you can't parse XML with regex.
Message 10 of 13
(355 Views)
