Building a package - "add to feed" checkbox not persistent
In the LabVIEW Project I am using a "package" build to create a .NIPKG containing my executable. I would like this to automatically get added to my feed which is on a network server.
In the "feed" tab I can check "add to feed" and specify the location. When building the package it gets added to the feed and all is well.
When I open up the build specs to edit the package build properties, the "add to feed" box is unchecked every time. Is this the intended behavior? My PC can still see the network location.
Running LV 2026 64-bit on a Hyper-V Windows 11 virtual machine.
(760 Views)
Can anyone confirm whether they see the same or different behavior?
(579 Views)
I don't see this but I'm also not on the same version as you, nor did I have a "proper" package build since I don't use them normally.
However, I did find that the properties page for that is something you can view as a VI, as are many other parts of the "Build" process.
LabVIEW 20xx\resource\Framework\Providers\Builds\Package\Common\Pages\Feed\Page.vi
It's not password protected either, so you can mess with it if you dare.  You could, in theory, try to add debug code and such to see if you can get any hints.
(555 Views)
