le 02-24-2011 10:31 AM
I have a XControl of mine where I handle the "pane resize" event to arrange its facade according to different control size.
When I put it on a front panel, and change its size, the FP's VI gets unsaved changes each time I open it, which is a bit disturbing. When I look at the "list unsaved changes" dialog it says "the display format of FP objects changed"
I tried several "Make current values default" but without success.
What can I do to suppress this behavior?
Résolu ! Accéder à la solution.
le 02-25-2011 07:52 AM
Making the facade event active only for run mode solved my problem
