02-23-2011 12:26 PM
I am trying to install LV2010 but all my attempts have failed so far. I installed it -> reboot -> the error message came "The installation of this application may be corrupt" [or something very similar]. I couldn't even run the License manager or any sort of NI softwares because the same error message popped up. Then I deleted the complete National Instruments folder from the Program Files, stopped all NI services in the Control Panel - Administration tools and rebooted the computer.
After all that I tried to reinstall LV2010 but I got the error message during the installation that at first "Labview 2010 must be installed" [or something very similar]. At one software component the installer told me that "Labview 8.6 must be installed"...
Does somebody have an idea how to proceed?
The OS is Vista.
Krivan
02-25-2011 06:48 AM
Have you started the setup process with administrative rights ( right click --> run as administrator ) ?
02-25-2011 07:02 AM
Hi Krivan,
It sounds like you need to clean up your registry.
Give this link a lookover. If it doesn't help please post back.
http://digital.ni.com/public.nsf/allkb/8703592D07C91AD586256B44000248C6?OpenDocument
Best Regards,
Chris
02-25-2011 07:02 AM
On my computer I am the administrator.
02-25-2011 07:38 AM
To be logged in as an admin isn't good enough for VISTA. You should try to explicitly start the setup via the context menu.
02-25-2011 08:06 AM
Also what you may want to try is copying the disc to your hard drive and install from there. I have found that, that will work sometimes when all else fails. With vista, you are also going to have to babysit the thing to make sure a permissions dialog is being "allowed".
