XControl custom size on a front panel leads to permanent unsaved changes
I have a XControl of mine where I handle the "pane resize" event to arrange its facade according to different control size.
When I put it on a front panel, and change its size, the FP's VI gets unsaved changes each time I open it, which is a bit disturbing.  When I look at the "list unsaved changes" dialog it says "the display format of FP objects changed"
I tried several "Make current values default" but without success.
What can I do to suppress this behavior?
(2,515 Views)
Accepted by topic author CharlesB64
Making the facade event active only for run mode solved my problem
(2,476 Views)
