Writing MDSPlus Segmented Records
Has anyone been successful at writing segmented records into an MDSPlus tree from a Labview Application?  I have tried the LVOOP sample VIs downloaded from mdsplus.org, but can't even open an MDSPlus tree successfully  (Labview aborts).  I don't really want to use LVOOP, but that's all MDSPlus developers offer.  Let me know if anyone has written non-LVOOP Labview VIs to write segmented (a.k.a. trended data) records, specifically timestamped data.
Message 1 of 13
(5,482 Views)
I have been looking into this and sounds like this is only supported by LVOOP.
Here is a link with some information. This helps to get an interface between LabVIEW and MDSplus
http://www.mdsplus.org/index.php/Documentation:Tutorial:LabVIEW
Regards.
Message 2 of 13
(5,427 Views)
Thanks for replying!  its such a small niche topic that I didn't think I would get any replies.
I have read all articles on www.mdsplus.org regarding segmented records; downloaded the LVOOP libraries for Labview.  I cannot even open an MDSPlus tree with the LVOOP VI!  When the MDSPlus Open VI executes, Labview application disappears (aborts).
Message 3 of 13
(5,419 Views)
I have been looking for a way to do it without LVOOP. Al the information available is from the web site you mentioned. Did you get like an error code when LabVIEW aborts?
Regards
Message 4 of 13
(5,391 Views)
no error code, because all Labview windows immediately disappear -------  poof!
Message 5 of 13
(5,383 Views)
Where did you get the LabVIEW codes? can you attach them try them on my computer?
Message 6 of 13
(5,362 Views)
Thanks for looking into this.  Have you been successful?
I downloaded the MDSPlus LVOOP VIs & libraries here:
http://www.mdsplus.org/index.php/Latest_Windows_Distributions
in other words, the LVOOP mdsplus files install when you install MDSPlus, if you choose the right options.
Took the default install directory:
C:\Program Files (x86)\mdsobjects\labview\MDSplus
I am working with Labview 2014 SP1, 32-bit version on a Win7 64-bit.
attached a sample VI that aborts.
Message 7 of 13
(5,311 Views)
I am the author of the library. If you need further information on this write me.
Enrico
Message 8 of 13
(4,770 Views)
thanks for responding!
I have received a new code library from the MDSPlus developer; so I have solved my issue for now.
Gretchen
Message 9 of 13
(4,760 Views)
Hello, can you share the files you found, I am also researching LVoop recently, sorry for your inconvenience
Message 10 of 13
(3,108 Views)
