Write to Measurement File
A direct build array returns a 2d array with the format that you want.
Message 11 of 12
(662 Views)
But this appears to be the result of indexing out of a for loop a value and the iteration count in an array together, when the array was the indexing input of the for loop.
Transpose array is surely the correct programatic approach to this, not building an array inside a For loop using a Shift Register which is what your method would require muks!
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
Message 12 of 12
(650 Views)
