Write to Measurement File
I'm trying to read out some data from a machines , so I add a Write to Measurement File, and it comes out to a *.lvm, I open it by txt, in the txt it looks like:
X_Value Untitled               Comment
0.000000                        147.970000
can I set the number at left into some letters? To show it more clear to the user
is it possible to change the 0.00000 at left into U1_rms?
I think it will be easier for the user to understand what is the meaning of value
Message 1 of 12
(5,375 Views)
duplicate post (already solved...)
Message 2 of 12
(5,373 Views)
sorry , I also send that message , but I found i just got the answer to my first part of the question, so I ask the question again , hope someone can help me
Message 3 of 12
(5,369 Views)
You can continue in the same thread right?
Message 4 of 12
(5,362 Views)
yes , do you have any advises for me ?
Message 5 of 12
(5,357 Views)
Yes,
1) Mark Gerd's post as the answer.
2) Go back to the other thread to get the second bit solved by people who are clued up with what you are trying to do!!Smiley Wink
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
Message 6 of 12
(5,328 Views)
I write a For loop for my labview, so here my question is Write to Measurement File read out like
0.000000               147.270000
1.000000               147.470000
2.000000               146.780000
3.000000               1.384000
4.000000               1.399000
5.000000               1.360000
can I change it into one row , so that new information come in, I can compare them in the same column , it's easier for me to see the difference.
Message 7 of 12
(5,320 Views)
0.000000               147.270000
1.000000               147.470000
2.000000               146.780000
3.000000               1.384000
4.000000               1.399000
5.000000               1.360000
Do you mean like this?
Message 8 of 12
(5,316 Views)
here is what i got
0.000000               147.270000
1.000000               147.470000
2.000000               146.780000
3.000000               1.384000
4.000000               1.399000
5.000000               1.360000
and I hope I can  change it to
0.00000            1.00000                       2.00000                3.000000          4.0000                      5.00000
147.27                 147.47                        146.78                  1.384                  1.3999                    1.3600
so when new data come in , it writes under the second row, it is easier for me to compare
Message 9 of 12
(5,280 Views)
it seems you're looking for the TransposeArray function... And still don't use the original thread...
Message 10 of 12
(5,277 Views)
