Wiring the conditional terminal of a while loop created by LabVIEW Scripting
I have written a VI creating a scripted VI that contains a while loop. So far so good. The problem is that I want to wire a boolean control to the conditional terminal of that while loop. I thought I could do that by either using a property node or an invoke node, but I could not find a way to access the terminal.
Does anyone know how to access the conditional terminal using a node or have another idea to solve the problem?
Steffen.
(5,663 Views)
I am not sure why you need property node or invoke node.  you can right click at conditional termonal and create control. Refer this.
Kudos are (always) welcome for the good post. 🙂
(5,661 Views)
When you have created the loop, you can then get references to all the objects in the loop (and maybe the conditional terminal itself, I do not have access to LabVIEW at the moment to check). You can loop through these to find the conditional terminal by trying to coerce to a conditional terminal and looking at errors. Use a connect wire method to connect your terminals.
(5,651 Views)
@ odessy27:
Because the VI in question is being created using VI scripting and the wiring is supposed to be created the same way... And since I have not found a way to wire two non-existent objects YET, using nodes seems like a logic way to try it...
(5,636 Views)
This is what I have so far, but it does not work that way. The VI produces error 1062.
(5,634 Views)
Accepted by LordSnow
Hi no87,
as attachment you will find a complete example.
Hope that help.
Best regards
Dippi
(5,604 Views)
Thanks, that solved my problem!
(5,595 Views)
