05-17-2021 02:07 PM
I'm unable to connect the orange big wires to the numeric meters. I want to display the value comming from these wires on the numeric meter. Does someone know how I can do this?
05-17-2021 02:37 PM
You have an array of numbers. The indicators take a single scalar. Which of the array do you want to display? The first, last, the mean?
You can use Index Array to get a particular scalar out of the array. You can use Mean to average them together.
05-18-2021 09:22 AM
If you are trying to display an array then you need an array of indicators
05-18-2021 01:09 PM
I recommend to start with the basic tutorials and learning resources listed at the top of the forum.
To get help, attaching a blurry tiny picture is not useful. The only thing we can glean is that you probably need significantly more help that just to solve your scalar/array problem. To get better help, attach your (broken) VI instead. Explain what it is supposed to solve and how it should be used (typical input values, expected result, sample data file, etc.).
Most likely you have only used "baby LabVIEW" (express VIs & dynamic data wires) until now, because you can wire a scalar indicator to a dynamic data wire, no matter how much data it contains.
Some glaring no-nos visible in your current picture:
