Windows messaging
I am interested to know how to communicate with another program using
Windows messaging from LabVIEW. I did not develop the program with which I
want to communicate. The developer allows other programs to interact with
it using Windows messaging.
I need to post messages to that application and receive messages from that
application. The application does not use Windows message ID's. Instead it
uses a message name. The message ID can be determined using a Win32 call,
RegisterWindowMessage().
National Instruments has an example LabVIEW 5.1 program with a C++ DLL that
receives messages, although it does not post messages. It works with
message ID's. Unfortunately, I cannot even get the C++ to compile using
Microsoft C++ 6.0. Something about "redefinition of Occur".
The developer of the application knows that they have customers who are
interfacing with their software using LabVIEW. The developer does not know
the particulars. But they did say that some big name companies are doing
it. Darn, I wish I had their budget.
I attempted to write a VB.NET 2.0 Windows control and use WndProc() to
handle messages. It just sat there. Even when I called it from a VB.NET
2.0 containing form. It responds to messages from the application, but not
from an external application.
I have a VB.NET 1.1 program that overrides WndProc() in the Windows form.
It behaves. I can receive messages and post messages. Now if I can only
teach LabVIEW how to do that!
I am an application programmer. I did not expect to have to get this
intimate with Windows. Is there someone who has done this from LabVIEW or
can steer me through some of the issues. I would be delighted.
Hamilton Woods
Message 1 of 25
(7,259 Views)
Message 2 of 25
(7,234 Views)
Message 3 of 25
(7,232 Views)
Hi Hamilton,
Did those example programs linked above help (are you working in LabVIEW 2009)? You can also use LabVIEW to call a DLL, would you consider calling your DLL in LabVIEW?
I'd like to get a little more background information from you.  What kind of messages do you need to post back to windows?  What version of LabVIEW are you working in?  Windows version? 64 or 32 bit?
Cheers,
Marti C
NI Medical
Message 4 of 25
(7,214 Views)
> Thanks, Hamilton Woods
This newsgroups is not frequently used.
See:
http://forums.ni.com/ni/board?board.id=170
Message 5 of 25
(7,213 Views)
Marti,
Thanks for your response.
I am using LabVIEW 8.5.  I am pretty sure that the Microsoft Visual C++ DLL source has not been
updated on the NI Developer Zone.  I was unable to get it to compile.  I was thinking that I might
extend it to allow message posting as well.  I am pretty sure that I am going to use a different
solution.
The provider of the3rd party app sent me a zip file with a Delphi example.  It turns out that the
zip file also contained a .NET 1.1 example as well.  I have that example doing what I need to do
from within LabVIEW.  Basically, I need to listen for specific messages (WM_CIRRIS_APP0 through
WM_CIRRIS_APP19) and to broadcast messages for the 3rd party app to receive.
I created a .NET 2.0 custom control (WndProc() lives as a protected method of a control) that I
instantiated in LabVIEW.  The custom control received no messages.
If I cannot solve the issue any other way, I will write a .NET application that sits between LabVIEW
and the 3rd party app.  I will use something (probably sockets) to communicate between
LabVIEW the .NET application.  I will, obviously, use Windows messaging to communicate
between the .NET application and the 3rd party app.
Thanks again for all the responses to my question,
Hamilton Woods, Certified LabVIEW weanie
Message 6 of 25
(7,201 Views)
One correction - replace
"I have that example doing what I need to do from within LabVIEW"
with
"I have that example doing what I need to do.  Now I need to figure
out how to do that from with LabVIEW"
Thanks again, and have a blessed day,
Hamilton Woods
Message 7 of 25
(7,199 Views)
Hamilton,
I think you are making this more complicated than it needs to be.  Muks was pointing you in the right direction... My LabVIEW app uses a USB security dongle that posts messages when it is plugged in or removed.   The app has to receive these messages to decide whether to run or not.  I used the same files Muks pointed at - it really is pretty straightforward.
I'm not allowed to send out my VIs, but take a look at these screenshots.  All you have to do is create the message queue, and then pass the hwnd and queue around as needed.
Jason
Message 8 of 25
(7,177 Views)
See:
Where do you think you are?
This IS the National Instruments discussion forum linked to by the web address you gave.
Message 9 of 25
(7,175 Views)
I think that poster is probably accessing the forums through a newsreader and not a web browser.
Message 10 of 25
(7,161 Views)
