How can I restructure an unfavourable 2D array format to 1D?
A surface profilometer we use produces data in text files with five columns with data point ordering by row first; i.e. if you have the following data sample;
1      2      3      4      5
6      7      8      9     10
11    12    13    14    15
Then the data order follows the number order here.  I want to chop up this annoying format into multiple arrays by row (depending on the number of rows = for loop?) then splice them back together as a single column (transpose these arrays then build array?). Help!
Message 1 of 18
(5,427 Views)
Read from spreadsheet file and reshape array might be enough.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 18
(5,418 Views)
You've just described one solution. Autoindexing will take into account the number of rows present - you could easily build the for loop by taking the array size and feeding the number of rows to it, but autoindexing does this for you.
CLA
Message 3 of 18
(5,416 Views)
That's the other solution I'd thought of - find the array size of the input array, index array twice to find row and column sizes, then feed in as the dimension for Reshape Array.
CLA
Message 4 of 18
(5,413 Views)
Are you asking how to take a 2-D array and transpose it?  If so, I recommend using the Transpose 2D Array function found on the Array Palette.  [I'm sure you already thought of that, which means that I don't understand your problem ...].
Message 5 of 18
(5,383 Views)
Accepted by topic author apg504
1      2      3      4      5
6      7      8      9     10
11    12    13    14    15
Once you have a 1D array, the concept of rows and columns no longer exists.
In any case, reshaping is the right thing. Here's what I would do:
Message 6 of 18
(5,380 Views)
And if you want a single colum 2D array output, just modify as needed, e.g. as follows:
Message 7 of 18
(5,378 Views)
I was right, I didn't understand the problem (later posts cleared it up).  I think the most "intuitive" (easiest-to-understand) way to do this is to simply feed the 2D Array into a For loop and use a Concatenating Tunnel at the far end to reassemble the pieces as a single 1D Array.  I don't know how this compares in speed to the reshaping solutions, but (a) I'm sure the time difference (in the context of your entire program) is trivial, and (b) there's something to be said for a "dirt-simple solution" that can easily be seen to do what you want.
BS
P.S. -- the output tunnel shown here is a LabVIEW 2012 "new feature".  It may well be that in earlier versions of LabVIEW, it would not be so intuitive ...
Message 8 of 18
(5,367 Views)
BS
Trust me, the Reshape Array that Altenbach showed is much easier to understand and will run a lot faster.
Message 9 of 18
(5,361 Views)
As Ronald Reagan used to say (and as Darren Nattinger has so well demonstrated at NI Week), "Trust, but Verify".  I wrote a routine where you specify the rows and columns of an array, builds a 2-D array (using nested For Loops) containing random doubles.  It then passes this array through Altenbach's "Reshape" routine, and through my "For-loop concatenate" routine, timing how long it takes each routine.
In LabVIEW 2012 on my 3-year-old Windows 7 PC, here are the times, in microseconds (there's some variability, but these are representative):
   Array Size            Altenbach            BS
      3 by 4                    43                   11
   300 by 400             9866                 285
What this means is that the clever guys at NI have really optimized array processing in For loops (I recall one of Darren's Timing challenges about three years ago at NI Week involved something like this).
P.S. -- I teach (as well as "do") LabVIEW, and also am willing to challenge the assertion that "the Reshape Array that Altenbach showed is much easier to understand" -- it strongly depends on your audience.
Message 10 of 18
(5,298 Views)
