01-23-2012 05:50 PM
Instead on my pc I can't change the sample rate. I don't understand the reason of it
01-23-2012 06:48 PM
01-24-2012 03:39 AM
Dennis Knutson ha scritto:
Another strange thing I noticed is your sample rate. You have it set to .5S/sec. With it set to something reasonable (i.e. 500 or 1000) and the correct Convert to Dynamic Data, the dt in the file is correct.
Thanks a lot, you were on right: the sample rate was too slow, I didn't recognize it could be a problem since the simulated device I used was the 9234 and in the specification sheet it is written just the max sample rate.Anyway thank you very much!
01-24-2012 04:03 AM
Another question: the sample rate doesn't match perfectly, but it is slighly different, as example I set up 5000 sample/sec and on the saved data I got a sample rate of 5100Hz. Is it normal?
