Why sample rate is different than I set up?
Instead on my pc I can't change the sample rate. I don't understand the reason of it
Message 21 of 24
(459 Views)
What's your device? Look in the manual to see what rates are supported.
Message 22 of 24
(454 Views)
Dennis Knutson ha scritto:
Another strange thing I noticed is your sample rate. You have it set to .5S/sec. With it set to something reasonable (i.e. 500 or 1000) and the correct Convert to Dynamic Data, the dt in the file is correct.
Thanks a lot, you were on right: the sample rate was too slow, I didn't recognize it could be a problem since the simulated device I used was the 9234 and in the specification sheet it is written just the max sample rate.Anyway thank you very much!
Message 23 of 24
(445 Views)
Another question: the sample rate doesn't match perfectly, but it is slighly different, as example I set up 5000 sample/sec and on the saved data I got a sample rate of 5100Hz. Is it normal?
Message 24 of 24
(442 Views)
