01-17-2012 10:00 AM - edited 01-17-2012 10:08 AM
Hi all,
I have set up an easy VI for understanding how nidaq-mx works. In the attachment you can find the VI. In particular the sample rate is set to 1Hz and I read 4 samples in 4 loops. So the acquisition should take 4 secs, isn't it? So why does it take just 0.03secs?
Thank you
01-17-2012 10:23 AM
Although your sample rate on your DAQ-MX may be set up to sample at 1 Hz, your loop can run much much faster. I would try adding the wait function into your loop to assure that the loop takes at least 1 second if that is your desire.
Hope this helps.
-Franklin
01-17-2012 10:38 AM
pierluk wrote:I have set up an easy VI for understanding how nidaq-mx works. In the attachment you can find the VI. In particular the sample rate is set to 1Hz and I read 4 samples in 4 loops. So the acquisition should take 4 secs, isn't it? So why does it take just 0.03secs?
It does not! I am currently on a laptop using a simulated device, but the VI takes over 4 seconds to complete. I suspect that you create an error in your initial DAQ setup, causing all IO to instantly error out and complete.
There are quite a few things a bit strange with your VI:
01-17-2012 10:42 AM
This is incorrect. The read timeout is 10 seconds by default, meaning it will wait 10 seconds if no sample is available. This is sufficient to never timeout with a 1Hz sampling rate and the sampling rate will primarily determine the loop rate as it should be.
Adding an additional delay introduces a second timing dependency, possibly causing problems in the long run.
01-20-2012 04:53 AM
Tanks for your reply. In the beginning I set up the NI-DAQMX Read in reading 10 samples, but the VI runs really fast. So I just tried to read only one sample for each iteration, but nothing changes. When I execute the VI I don't get any error and the right amount of samples. When in the waveform properties I get the dt is 1 for any sample rate I set up. I don't understand what's wrong on my VI
01-20-2012 09:28 AM
Post your new VI. In your original, you don't have a waveform data type anywhere at all and any dt that you write to the file is garbage/default value since you are not passing any dt value to the Write to Measurement File function.
01-23-2012 07:38 AM
Thanks again for your reply, this is the new VI.
01-23-2012 10:40 AM
I never use dynamic data or the write to measurement file but your Convert to Dynamic Data looks wrong. You have a conversion dot on the input. Why did you select the input type as 1D Array of Scalars (which has no timestamp) instead of Single Waveform?
01-23-2012 11:24 AM
I already did it, but it doens't change anything. I don't understand what's wrong with that VI.
01-23-2012 11:34 AM
Another strange thing I noticed is your sample rate. You have it set to .5S/sec. With it set to something reasonable (i.e. 500 or 1000) and the correct Convert to Dynamic Data, the dt in the file is correct.
