in data 08-23-2005 01:24 PM
in data 08-23-2005 01:34 PM
in data 08-23-2005 02:37 PM
in data 08-23-2005 02:50 PM
in data 08-23-2005 03:03 PM
in data 10-27-2011 05:18 AM
The problem I am facing is somewhat related to the above mentioned issue.
My objective is to make a sweeping spectrogram, i.e... As the data comes in, calculate spectrogram and display on intensity chart. Now the issue is to make the transition/sweep as smooth as possible. But I observed two problems with my implementation.
1) First, there is flicker in the display, to understand that please refer to the image I shared named "flicker in sliding intensity chart.jpg" and run "sliding 2d array general.vi".
2) Second, there a random minor change in the contents of the spectrogram as the spectrogram sweeps. To understand this problem please run "FileReadSpecPlot5.vi". Notice the small blue dots in the sweeping spectrogram, they are also flickering instead of only sweeping to the left.
P.S.. They are not my original VIs, they are just prototype. Original project VIs are larger enough.
Abubakar Rehman
NI Research Officer at National Systems
in data 10-27-2011 02:04 PM
Can you place reasonable data in to the Oarray and Narray controls, make their current values default, and re-save the VI so we have something to work with?
(I would also recommend an algorithm that operates "in place").
in data 10-27-2011 02:29 PM
SpoilerIt should not make me smile but it did. Christian has a total 7 tags and five of them are variations on "in place".
Ben
