Whole word string replacement in LV7.1
Is there anyway to do whole word string replacement in 7.1?
For example, if I have the string "x21+sin(x2)" and I want to replace "x2" with "b2" without accidently changing "x21" into "b21". I saw that 7.1 does not support the word boundary "\b" in regex.
(2,515 Views)
The easy solution is to search for "(x2)" and replace with "(b2)" but if you're not sure that x2 will always be in parenthesis, then another solution would be to get the next character after "x2" is found, and if it is not a number (0-9) then you have found x2, if it is a number then you have found x21, or x22, etc.
(2,503 Views)
