Read from graph
I would like to check whether is LV able to read Y axis values based on given X axis values. The graph is already plotted with few points.
Message 1 of 8
(4,145 Views)
Is your data in an array?
If so, you can use 'search array' to find the index of a given x value.
Then use 'index array' to find the y-value at that index.
If the y-value you want to find does not yet have an x-value,
you must either interpolate or extrapolate accordingly.
Cory K
Message 2 of 8
(4,141 Views)
Are you referring to a "waveform chart" or a "waveform graph" It is easy to confuse those two
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 3 of 8
(4,137 Views)
Thank you for the fast replies from you guys. I attached my VI.
My problem is based on the graph i had. How do i get data for 20k based on the graph? I understand that the array to generate this graph do not have the data in the array. How should i go about doing this? Hope someone enlighten me.
Ander
Message 4 of 8
(4,130 Views)
You can interpolate to find points in between the ones you already have:
The output array, yi, will be 2,000,000 points.
You can index the array, at 20,000 as you said, to find the y-value.
You an do the same for any value you would like to find.
Message Edited by Cory K on 06-17-2009 10:48 AM
Cory K
Message 5 of 8
(4,124 Views)
Hi Cory,
I can't get 20k for the value of 43 based on the block diagram.
Message 6 of 8
(4,114 Views)
When I used the code I posted above, when I entered an x-value of 20,000
I got 41.444 back. Is that correct or no?
Cory K
Message 7 of 8
(4,099 Views)
Perhaps looking at the Get Y Value example will help you.
Tim Elsey
Certified LabVIEW Architect
Message 8 of 8
(4,084 Views)
