Where is this
how do I get this to show up?
(2,944 Views)
Here:
(2,922 Views)
Right-click the graph terminal...create...property node...xscale...offset and multiplier...multiplier.
(2,919 Views)
Right-click on your graph and choose to Create->Property Node and then find X-Scale->Offset And Multiplier->Multiplier.
(2,911 Views)
You probably should have kept that in the original discussion.
There are also ways to avoid that property node:
Note that waveform graphs also accept clusters of (x0, dx, [Y]), and waveform datatypes, allowing you to define dx without any property node. Two simple alternatives would be the following:
(2,905 Views)
