Where is this
how do I get this to show up?
(1,283 Views)
Here:
(1,261 Views)
Right-click the graph terminal...create...property node...xscale...offset and multiplier...multiplier.
(1,258 Views)
Right-click on your graph and choose to Create->Property Node and then find X-Scale->Offset And Multiplier->Multiplier.
GCentral
(1,250 Views)
You probably should have kept that in the original discussion.
There are also ways to avoid that property node:
Note that waveform graphs also accept clusters of (x0, dx, [Y]), and waveform datatypes, allowing you to define dx without any property node. Two simple alternatives would be the following:
(1,244 Views)
