Where is the state diagram toolkit supposed to show up after installation?
I installed the state diagram toolkit for 8.21 but can't find it to use
One should welcome adversity as an opportunity to excel.
Message 1 of 11
(3,819 Views)
Hi Daddy-O
In the add-ons list.
Ton
Message Edited by TonP on 07-23-2007 03:57 PM
My LabVIEW Ideas
Message 2 of 11
(3,815 Views)
Even though I have the full Developer's Suite, this is all that shows up in the add-on tab.
Advanced Signal Processing
VI Analyzer
Control
Thanks.
Message 3 of 11
(3,804 Views)
VI Analyzer
Control
Thanks.
Message 4 of 11
(3,799 Views)
Did you close Labview and re-start it?  Sometimes you have to re-start Labview for new toolkits to show up.
- tbob
Inventor of the WORM Global
Message 5 of 11
(3,787 Views)
I have rebooted multiple times, I tried uninstalling and reinstalling, repair, and modify versions of the setup. Thinking that it went somewhere unforeseen, I even searched for it multiple times, and the toolkit doesn't appear to reside anywhere on my hard drive...
Message 6 of 11
(3,777 Views)
I don't have the toolkit but does it require activation with the license manager?
Message 7 of 11
(3,770 Views)
Did you install it?
It requires an seperate install of the SDE toolkit.
Ben
Message 8 of 11
(3,764 Views)
I am not sure, but I did notice it is installed on my LabVIEW 8.0 directory. I reinstalled all of the toolkits (about 15 or 20) and all it asked for was serial number. I looked to make sure it was copying them into the proper (8.2 vi.lib) and it looked like it was, (it indicated it was going to install on Program Files\National Instruments\LabVIEW 8.2\vi.lib\) but they did not appear either in the vi.lib directory or the addon library. It' s like the installation didn't take. I have restarted, rebooted and still nothing.  This is related to the post I had last week where I basically have to build a state machine (consumer / producer with queues) to be able to use multiple AI tasks "simultaneously". I was hoping that this state diagram toolkit would be an easy way to build the base architecture. Now I have spent 1/2 of a day just trying to install it.
Message 9 of 11
(3,755 Views)
Try removing the toolkit and then reinstalling just that one.  Toolkits are supposed to install in the latest version directory.
- tbob
Message 10 of 11
(3,750 Views)
