When PC System timing hits 0000hrs Loops back to start and runs again using Loop function?
Message 1 of 57
(4,344 Views)
I'm sorry, but I don't understand your question at all. Can you please rephrase it, or provide more details? If you have code please post it and indicate what the problem is.
Message 2 of 57
(4,337 Views)
Having a VI.
Is it possible to rely on the PC System timing to auto re-run the VI
when the moment the system timing hits 0000hrs with a new date?
Message 3 of 57
(4,333 Views)
Depends on your  coding.
One way is to simulate the condition by manually changing the PC time to 23:55hrs and then run the vi. See if the expected result occurs when the date changes.
Thanks.
Message 4 of 57
(4,319 Views)
Looking at your existing code, you would be better off using the windows task scheduler. No LabVIEW code required.
Message 5 of 57
(4,316 Views)
windows task scheduler?
how is it gt done by off it?
Message 6 of 57
(4,305 Views)
What?
Message 7 of 57
(4,286 Views)
any steps solution to solve?
Message 8 of 57
(4,238 Views)
It's all described in the help for it. Vista version:
Message 9 of 57
(4,230 Views)
how to apply Task scheduler on LabVIEW as u mentioned?
Message 10 of 57
(4,226 Views)
