10-10-2010 09:51 PM
Ravens Fan,
true... email doubt can do that. i forgot.
but i upload online.
http://www.4shared.com/file/pLq892VP/Lijun_AMK.html
able to download from here and extract under a same folder.
The MAIN VI for this project is : AMK_solarmonitoringsystem_vi.vi
Thanks.
regards.
10-10-2010 09:52 PM
Don't ever use the run continuous mode. Before posing any code, fix that.
"Don't ever use the run continuous mode" ???
regards.
10-10-2010 09:55 PM
That is correct, don't. It's for special debug purposes. Use an actual while loop.
10-10-2010 09:57 PM
Dennis,
i tried ways... none helps yet
perhaps i never use the correct method or not enough.
regards.
10-10-2010 10:53 PM
And never post a VI that is set to run when opened!![]()
You've got major dataflow problems. This goes back to your first post. You did not even try what I said to do in order to enfoce the sequnce. You then implemented the flat sequence structure badly.
10-10-2010 11:02 PM
i know i lousy, thats why need help badly.
10-11-2010 09:48 PM
anyone out there able to help or coach me on the problem issue i facing??
need the help badly...
david
